Tractor Talk Discussion Forum
Tractor Models
Craig in Ohio
02-18-2006 07:40:25
I was just curious about this. Of those tractors like the Ford NAA, the Allis Chalmers WD and WC, and the Case VAC amoung others, were these letters abbreviations for something?
Bob M
02-18-2006 15:52:31
 Re: Tractor Models in reply to Craig in Ohio, 02-18-2006 07:40:25
Craig - For Minneapolis Moline at least, model letters were signficant in the late 40's/early 50's. MM used 3 letter model designations:
- 1st letter = series (size) eg. Z, R, U, G. In themselves the letters had no meaning other than to designate the series - 2nd letter = T (for "tractor")
- 3rd letter = type
The major types:
U = universal (narrow front and adjustable rear tread)
S = standard (fixed wide front and fixed rear tread)
C = cane (fixed wide front hi-clearance)
I = industrial (fixed, heavy duty wide front)
E = extendable (adjustable tread wide front)
N = single front wheel
(There were a few more "type" letter but I cannot recall them offhand...)
Examples: A UTS is a U-series tractor with a standard tread front end. An RTU is a R-series with a narrow front end, etc.
However in about 1952 when MM came out with the improved "B" series, diesel and butane engines, etc. this model numbering scheme kinda fell apart.
JDknut
02-18-2006 11:34:05
The only light I can shed on this, and it is only a glimmer rather than a light is that Henry Ford always used the letter "N" to refer to tractors made by the Ford Motor Company after the Fordson and before the first hundred series in the mid-'50's. The number referred to the last digit of the year of introduction hence the 9N was a tractor introduced in 1939, the 2N a tractor introduced in 1942, etc. The NAA, the Jubilee, well that kept the "N' format but I am not sure about where the "AA" came from, maybe becasue it was a complete new design, without the Ferguson patent influence.
big jt
02-18-2006 08:25:04
Need to offer a slight correction to my last post. The "VA" was the standard version of that series. Have a case of C.R.S. with the VAS.
jt
big jt
02-18-2006 08:20:57
The simple answer to your question is Yes and No.
The models you listed are a prime example.
Two of them (WD & NAA) had no reference for anything to the buying public.
The other two (WC & VAC), The "C" stands for row crop version's of the W and VA series tractors in those lines. Allis had the WF which was a standard tread version of the WC. CASE had the VAS (Standard tread)
VAO (Orchard)
VAI (Industrial)
VAIW (Industrial Warehouse tug tractor) VAH (High crop)
The "A" with Case indicates it was the second design of the basic tractor. The VA series isn't such a good example as the V series was really only similiar in outward appearance. Better example with CASE is the L and LA. To further complicate this the C series and D series Case's were very similiar but they changed the first letter, go figure!
To make it even more complicated not everyone used the same designations.
Hope this helps
jt
Craig in Ohio
02-18-2006 09:10:43
 Re: Tractor Models in reply to big jt, 02-18-2006 08:20:57
Thanks, jt. Once again I will say if you want to know something about tractors the guys on this discussion forum will come through for you.
J.C.H.
02-18-2006 08:18:41
I do not know what they mean but I suspect that they are each Companies Catalog efforts to differentiate between each Model.
