Tractor Talk Discussion Forum
37 Chief - 14.5 tires again
oleblu
02-18-2006 12:12:16
I looked up the specs on the 14.5's 7-14.5 Load range D (8 ply) Section width (SW) is 7.3 and Overall diam (OD) is 26.6 Load rating PER TIRE- SINGLE is 1875 @ 70 PSI, DUAL is 1655 @ 70 PSI 8-14.5 Load range F (12 ply) SW is 8.0 and OD is 27.8 Load rating PER TIRE - SINGLE is 2835 @ 100 PSI and DUAL is 2470 @ 100 PSI Both the 7-14.5 and the 8-14.5 are designed to go on a 6" wide rim. I stand corrected that FIRESTONE does NOT make any 14.5 tires, their Road King Division does. If you put the 7-14.5's on your trailer I don't think you will be able to maintain the 13,ooo GVW.
37 chief
02-18-2006 23:44:25
 Re: 37 Chief - 14.5 tires again in reply to oleblu, 02-18-2006 12:12:16
Thanks for the info, Looks like I better stay with the 800 X 14.5 Stan
