Tractor Talk Discussion Forum
john deere a stuck
Zach1216
02-19-2006 19:36:10
I recently bought i john deere a from a guy for $800 it was missing a carb,but got a carb on it. Me and my dad tried pull starting it today and got it runing drove it around for about 5 mins and it died. we got it runing again and was driving for about 10 minuts and it died.we couldnt find any reason for it thought maybe be a fuel problem and tried to start it again and it wouldnt budge even pulling it the tires just slide any help would be great. thanks in advance
Farmered
02-20-2006 05:24:20
 Re: john deere a stuck in reply to Zach1216, 02-19-2006 19:36:10
Zach, be careful! If the cylinders are full of gas don't just grab the flywheel and give it a turn with the plugs out. Had a friend and neighbor who was burned to death right in front of his family by turning the flywheel to clear gas out of a flooded engine. The plug wire was hanging right in front of the vacant spark plug hole. When he turned the flywheel he was sprayed with flaming gas. Ed
Eric Perry
02-19-2006 21:38:56
Zach, try puliing out the spark plugs and see if it will turn over then. I had an 8N ford that the carburator float stuck open and it filled the cylinders with gas and the starter could only turn it about a quarter of a turn before it bound up. A bad head gasket that leaks water into the cylinder could also do the same thing.
Good luck!
old
02-19-2006 20:47:40
As Gene says did you have oil preassure?? If not you may have big trouble. I may self would not use PB but instead tranny fluid. Cheaper and does the same thing. If you didn"t have oil preassure its not hard to fix the coupler problem
LBH
02-19-2006 20:16:09
I would pull the spark plugs and spray some PB Blaster in there and let it sit a day or so. Then i would try to turn it over again. Remember to change your oil after you get it started to get rid of the PB Blaster or you can pour some marvel mystery oil in the spark holes to help free up the stuck engine.
Thanks,
LBH
Jeff In Ontario
02-19-2006 19:57:46
Sounds like you either didn"t have any oil in the engine or oil isn"t getting around everywhere in the engine and it seized up on you.
Gene Davis (Ga.)
02-19-2006 19:56:02
Did it have oil pressure? John Deeres were bad about the oil pump drive coupling breaking if water got in the oil pump and froze or stuck the gears. When the coupling shears and there is no oil pressure.
