Tractor Talk Discussion Forum
wiring a jd 60 switch
pipeliner
02-24-2006 02:50:46
I have rewired some of the old wiring on the 60 but have wired to the wrong post on the switch. Now I can start the tractor, the lights work ok but the switch won't shut the tractor off. I need some advice or a wiring diagram.
buickanddeere
02-24-2006 02:56:58
 Re: wiring a jd 60 switch in reply to pipeliner, 02-24-2006 02:50:46
1-800-522-7448 . It's in the model 60 service manual and the SM-2029 electrical manual. You could just check which posts make and break at each position. There are three different switches. The 6V cranking engine, 24V diesel and the 6/12V gasser. On the gasser switch one of the posts ties to chassis when the switch is placed to the off position.
