Tractor Talk Discussion Forum
1943 Farmall H Transmission
Corey Colt
02-26-2006 13:49:56
Tractor won't stay in 5th gear - all other gears are fine. Also, howling noise - not sure from where. Could all this be shifter lever related??
Corey Colt
02-26-2006 18:02:16
 Re: 1943 Farmall H Transmission in reply to Corey Colt, 02-26-2006 13:49:56
The tractor was recently purchased with this 5th gear problem. I had heard that there were issues with the shifter and wanted to start there. If this was ok I figured I would have to take the plate off and look at the gears. If the gear is bad, it sounds like it would be obvious. Do you agree?
farrviewsouth
02-27-2006 14:31:06
 Re: 1943 Farmall H Transmission in reply to Corey Colt, 02-26-2006 18:02:16
Yes, in terms of running, the teeth will likely be ground off more that the other gears. It doesn't pay to speed shift and H :> (Or so Dad kept saying)
farrviewsouth
02-26-2006 14:43:10
Is this a new issue? I do not know about the howling but many of the H's I have driven will not stay in 5th under a load due to the excess wear on the gear. You can remove the transmission cover and check the wear on the 5th gear.
