Tractor Talk Discussion Forum
3 Point Rototiller Size
Kentucky Farmer
02-26-2006 20:16:42
I'm tired of having to plow AND disk just to draw in Bambi!
Is a MF 35 Diesel (in top running condition) "big enough" to work a 6 ft roto-tiller (1-2 acre food plots)...the soil is relative "loose"? Or...should I "back down" to a 5 ft one?
phil lowe
02-27-2006 15:34:48
 Re: 3 Point Rototiller Size in reply to Kentucky Farmer-Hunter, 02-26-2006 20:16:42
I've been thinknig about this ,,,,I want ot work couple acres on my land ,,,possibley 3 ,,,have not bought the plow /dics's and harrows yet ,,,would a tiller be a better bet for me ,,,
PhilcaseinWPa
02-27-2006 06:56:25
Rule of thumb 3/4 horsepower for ever inch of tiller. 72" = 54 pto hp minimum. What if you just disk heavy and not plow every year?
Phil
Robert in W. Mi.
02-27-2006 06:55:06
third party image
All tillers "aren't" created equil, some go deeper, have a higher rotor speed or multi speed gear box, and have more tines per flange.
It takes about 60 PTO hp to run a 6' "field" tiller in "all" conditions, but a decent 35 or 40 PTO hp tractor will run a 6' "garden" tiller doing small plots.
If a 5 footer will cover the tire marks, that's what i'd get if i was you.
BTY, If you want it to last, get a Howard of the right size for your tractor and in the end it will be worth the extra it cost you...
Robert
Turtle
02-27-2006 03:42:54
Not sure if this applies to the massey or not but a friend of mine that has a 8N used my tiller and found it would not work properly because it would not go slow enough for the tiller to work. The gearing was a problem. Just a thought.
Robert in TN
02-27-2006 00:05:48
You would be pushing it with a 6' rototiller on the MF35. It may handle it as long as you run it shallow. I would go with the 5' and let it eat.
Keith-OR
02-26-2006 21:31:24
KF-H, I run a 60" Howard with a Ford 860 with an industrial 172 ci 50+ hp engine. Howard recommends 45+ Hp for their 60" tiller.HTH
Keith & Shawn
mud
02-26-2006 20:30:23
We use a 5' Howard Rotavator with a 42 hp Kubota with no trouble at all. You can select the depth and hit it twice if it is tough going. Hard to beat a Howard. Even used, they are a tough implement.
