Tractor Talk Discussion Forum
briggs 18hp twin flooding out
chris sweetland
03-01-2006 14:47:54
i have a briggs 18 hp twin cylinder that floods out its got a fuel pump so im a little baffeled anyone got any suggestions?
chris sweetland
03-01-2006 15:41:46
 Re: briggs 18hp twin flooding out in reply to chris sweetland, 03-01-2006 14:47:54
the olny thing i did to the tractor was put a set of head gaskets on and fire it up was sitting for a while and was pretty full of water but runs good other than the flooding out part
John M
03-01-2006 15:13:26
Have you rebuilt the carb?
chris sweetland
03-01-2006 15:07:02
while running gets too much gas and dies
old
03-01-2006 18:00:32
 Re: briggs 18hp twin flooding out in reply to chris sweetland, 03-01-2006 15:07:02
simple fix, rebuild the carb as that is the only thing that can/will cause your problem
Bob
03-01-2006 14:58:13
Define "floods out".
Does it get so much gas while it's running it begins to smoke, and then stalls?
Does it drain gas into the cylinders while it's shut off?
Or, is it just hard starting because of to much gas?
