Tractor Talk Discussion Forum
What is your opinion? - John Deere 4430
Tod in Ohio
03-04-2006 18:51:47
I am thinking about buying a John Deere 4430. The tractor will be used of some tillage, hay work, planting, plowing, etc. I wanted to find out opinions on these tractors.
Thanks,
Tod in Ohio
JMS/MN
03-05-2006 11:44:28
 Re: What is your opinion? - John Deere 4430 in reply to Tod in Ohio, 03-04-2006 18:51:47
Had my '74 since '80. 10700 hours, original (light) rear end. No engine overhauls, no PowerShift repair, no hydraulic repair other than a couple load shaft seal replacements. Did replace some fiber washers in the differential. Uses about 5 gph on plowing 5-18, 24 foot FC, silage chopping. Pint of oil in 100 hours- been that way since '80.
msb
03-04-2006 23:20:35
Some of the early ones had some rearend problems,but this one is probably past that by now if it was going to be a problem.I own two of them and I really like both of them(1 Quad range & 1 Power shift), but a 4440 is a better tractor if the price isn't that much more.
johndeeregene
03-04-2006 22:08:48
we had one for quite a few years had no problem with it at all. the next generation were even nicer. an i would have to differ about it being more thirty then the 4630. we also had a 4630. it was a pretty good ol gal but man did it burn the fuel. it would burn 12 gal ahour. johndeeregene
ricedaddy
03-04-2006 19:10:31
Have had two of them, no complaints at all! For a small tractor I think it will serve you well>
good luck
Ron
Bob
03-04-2006 18:55:25
Real good tractor. A little more fuel-thirsty than it's bigger brother, the intercooled 4630.
