Tractor Talk Discussion Forum
harry ferguson tractor identification
mike glenn
03-05-2006 13:41:37
hello-my dads farm has a old, harry ferguson tractor that the oil plug fell out of and ruined the engine. My Dad has painted over the tractor a few times, to the point where the letters on the tractor cannot be made out---took some stripper and exposed the ID tag on the column--
serial number is 23414-and at the bottom of the tag is written Harry Ferguson Inc Detroit Michigan
can anyone tell me what model this is, and where is a good place to get a new engine,parts, or a midwestern shop (Iowa located) that would do a good job rebuilding the engine.
thanks, Mike pollet 215-423-0100
B:L Whiteman
03-06-2006 07:09:35
 Re: harry ferguson tractor identification in reply to mike glenn, 03-05-2006 13:41:37
you have to see on that plate under the steering wheel- if the #s te 20 to20 it could be either one or just an old ford ferguson from the #s I would say it is prob a 47-48- or in there somewhere if I had the # and the TO- TE etc. I could tell you-- and as far as the engine try to start it(after you put oil in it) Ive seen these set up before and when loosened up by jogging the starter they ran pretty well maybe smoked a little some did not-- lots of luck
Jerry/MT
03-05-2006 16:09:50
Sounds like a TO-20. TO-30's were TO 60001 and up to about TO 140000. Look in the Research & Info section to the left of this page under serial Numbers and go to the Ferguson section.
toolman
03-05-2006 14:51:38
Mike , go down below on this site to the harry freguson board, those fellows down there will help you out with everything you need a great bunch and john uk knows just about everything you,ll ever need to know about these tractors.
