Tractor Talk Discussion Forum
diesel oil change hours
Pa Dave
03-05-2006 16:42:48
wondering how many hours you folks put on your diesel tractors befor you change engine oil? one of our tractor manuals says 100 hrs, while the other tractor suggests 200 hrs. open for debate
Pa Dave
03-06-2006 16:53:26
 Re: diesel oil change hours in reply to Pa Dave, 03-05-2006 16:42:48
one is a 990 David Brown calls for change at 200 hrs. other tractor is 1755 oliver i believe it calls for 100 hours.
Steven@AZ
03-06-2006 15:01:19
The oil in our tractors stays clean until around 75 hours, then it gets black and they start to burn oil. So we usually change around 75 to 100 hours. In the winter with short run times and poor operating conditions (farm is in ND) they get changed around 50 hours.
Don-Wi
03-05-2006 21:23:17
It depends on the tractor/engine involved. In our Massey 285 w/ a Perkins 4-318 and 12 qt. capacity(80-85 HP), I change it every 100 hours. In our Oliver 1855 w/ a Oliver/Waukesha 6-310 and 8 qt capacity (105 HP) I go every 50 at the most, sometimes more. I think the manual calls for 100 in both, but in the Ollie I'm just not gonna risk it. What tractors/models are you talking? makes a difference.
Donovan from Wisconsin
Bob
03-05-2006 19:10:04
Regular oil analysis can help set up an oil change schedule based on the actual conditions the tractor operates under.
Bill(Wis)
03-06-2006 16:49:39
 Re: diesel oil change hours in reply to Bob, 03-05-2006 19:10:04
Where do you have your oil analysis done and how much does it cost per tractor?
