Tractor Talk Discussion Forum
fuel to pull pup trailer
ross in ns
03-06-2006 16:09:51
hi all just curious if any one here has pulled a pup trailer behind a tandem truck i am thinking about getting one to pull behind my tandem and some fellows here say that you can double your pay load for about a quarter more of fuel use there saying if my tandem burns 20 gallons to make one trip without a trailer then it will only take about 25 gallons when pulling a pup behind any thoughts? thanks ross in ns
Leland
03-06-2006 21:10:40
 Re: fuel to pull pup trailer in reply to ross in ns, 03-06-2006 16:09:51
A semi gets 5-9 mpg pulling 80,000lbs so figure it from there .
Andrew from KY
03-06-2006 17:22:33
I think that it would ultimately depend on the motor in your truck. For example I think that if you had a 400 Cummins in one tandem grain truck and a 6v71 Detroit in another the Cummins would pull an additional 500 bushels or so easier than the Detroit would simply becuase it is a larger engine.
Andrew from KY
03-06-2006 17:21:48
I think that it would ultimately depend on the motor in your truck. For example I think that if you had a 400 Cummins in one tandem grain truck and a 6v71 Detroit in another the Cummins would pull an additional 500 bushels or so than the Detroit would simply becuase it is alarger engine.
