Tractor Talk Discussion Forum
Patching a punctured rear tractor tire
Rodney J
03-06-2006 16:55:21
Backed the bale spear right into the almost new rear tire on my Super C. What a sick feeling. Anyway, I've got a 1/4" diameter hole in the tire, although I must not have got the tube, as it has been holding air for the last two days. Is there a way to patch the hole in the tire to prevent future damage to the tube?
buickanddeere
03-07-2006 05:58:06
 Re: Patching a punctured rear tractor tire in reply to Rodney J, 03-06-2006 16:55:21
www.millertire.com sells a cold patch wonder glop to seal tire wounds. Install a boot inside covered with wonder glop. Inflate the tire to max recomended pressure. Fill the hole full of wonder glop. Deflat the tire down to it's normal 12-15psi working pressure after it's cured and hope for the best. With a clean 1/4" hole you should be ok.
Leland
03-06-2006 21:09:01
Take it to a tire shop and sent off to be sectioned this is were they bond a new piece of rubber in hole only way to go .
old
03-06-2006 17:49:44
You can put a boot in the tire to save the tube but the problem is even with a boot the cords will dry out faster on the tire. You can also find a place that valcanizes tires which will be a better fix but cost a lot more to have done. You can also boot the tire and then fill the hole with silicone sealer and it will last almost as long as haveing it valcanized
Keith-OR
03-06-2006 20:26:40
 Re: Patching a punctured rear tractor tire in reply to old, 03-06-2006 17:49:44
Hey Rich, you get lost today? Was thinking about calling you to see if anything was wrong. And don't tell us you were working on the MH...lol
You see the picture Mike in MI posted below?
Keith & Shawn
old
03-06-2006 20:36:22
 Re: Patching a punctured rear tractor tire in reply to Keith-OR, 03-06-2006 20:26:40
yep was working on one of the MHs which seems to want to be a parts tractor since it has a bad knock. MH 30. Started to wrok on the MH 44 but the battery had enough so I gave up for the day. Unloaded the Allis WD today and get to go pick up a load of hay tomorrow.
