Tractor Talk Discussion Forum
fairbanks and morse one cylinder
jlmtractor
03-06-2006 18:33:01
I recently purchased a b-80 wheel horse the year is unknown. It has a fairbanks and morse one cylinder motor. I cant get it running and it doesnt have any spark. I think it is the coil. Does any body know how to diagnose this problem?
Larry from md
03-07-2006 09:03:16
 Re: fairbanks and morse one cylinder in reply to jlmtractor , 03-06-2006 18:33:01
Most likely you have a wisconsen motor and you are reading the name on the magneto.
jlmtractor
03-07-2006 12:34:06
 Re: fairbanks and morse one cylinder in reply to Larry from md, 03-07-2006 09:03:16
yah that is right larry from md the plate on the side is covered in rust and i cant read the the make. and yes i am reading the plate on the magneto. i just took for granted that was the make of motor. thank you for the reply. by jlmtractor
Glen in TX
03-08-2006 10:05:10
 Re: fairbanks and morse one cylinder in reply to jlmtractor , 03-07-2006 12:34:06
FM did make a few air cooled engines but not many. Mag is probably a FM-J or FM-X and if number has a 7 in it like FM-J1B7 it's a Wisconsin. The 7 is mfg. code for Wisconsin engine. Probably need to change the points and condenser first. Set FM-J points at .020" and FM-X points at .015". Should be able to get tune up parrt at Napa or auto supply local. If not holler at me for parts. Coils are available and do go bad too but check for clean points and adjustment first. Points may only need cleaning.
