Tractor Talk Discussion Forum
Towing a JD450C
mcc92
03-06-2006 19:42:25
Is it safe to pull a 15000 lb JD 450C with a chevy diesel 3/4 ton pickup?
Brad Wright of MO
03-09-2006 13:31:52
 Re: Towing a JD450C in reply to mcc92, 03-06-2006 19:42:25
We haul 1800 pounds of Hay on a gooseneck trailer every summer for the past 15 years. It is a 91 Chevy 2500 gas and dosent have duel tires. It has a 350 in it. Of course thats not at highway speen we maby go 15 to 25 down gravel roads mostly. I dont know about the highway. I would think it would be fine though. (gooseneck only though and atleast electric trailer brakes.)
M Nut
03-08-2006 12:56:37
If on a gooseneck trailer rated for that weight capacity, I'd do it. Bumper pull, no.
mpuller2
03-07-2006 09:08:07
I would not just pull it. Load it on a trailer, maybe, and then with a dually only.
dugger
03-07-2006 06:07:45
if you have a good tandem trailer with brakes i would'nt be scared of it.
JDknut
03-07-2006 03:38:13
I wouldn't. But then, I wouldn't use a Chevy "Diesel" to pull a lawn tractor. (just kidding :-)) But. seriously now, that's just asking for trouble, pulling that size load with a way too small truck. That truck wouldn't get out of its own way, assuming you didn't break something right off the bat just trying to get it to move at all, and if you ever did get it moving, you'd never be able to stop it. I'd use a full size truck-C65 Chevy or equivalent.
buickanddeere
03-06-2006 21:29:36
We are glad to see you are smart enough to ask instead of going ahead and trying it. Wish there were more cautious people like you.
Leland
03-06-2006 21:04:35
For safety's sake rent or borrow a bigger truck ,if you have a accident they will take everything you own including you balls .
old
03-06-2006 20:40:05
Yes you can, but only if you have very good trailor brakes and you take it slow. Leave 3 times the space between you the the guy in front of you and never slam on the brakes. Better yet get a bigger truck and be safe.
2x4
03-06-2006 20:37:12
its not even safe towing a JD 350 that way. Once, that nearly killed a friend.
the tractor vet
03-06-2006 19:59:32
Well we pulled one with a 3/4 tonF250 4X4 ford onec and only once it was more then we wanted behind it . Oh BTW it was and older one you know back when they made a real truck not the toy junk of today. From that time on i just put it on the semi .
dhermesc
03-07-2006 07:01:03
 Re: Towing a JD450C in reply to the tractor vet, 03-06-2006 19:59:32
There is no comparing an "old" F250 to a new F250, its closer to compare an older F250 to a new F150.
A reg cab 2X4 1991 F250 with a 7.3 only had 180 hp @ 3300, torque of 345 @ 1400 RPM, weighed in at 3708 lbs, and towing was only 8200 lbs. The 1990s diesel was a horse compared to the earlier F250s. Trying to compare this to a 1970s F250 with a 390 will only show how far things had progressed.
A reg cab 2X4 2004 F250 with a 6.0 has 325 hp @ 3300 RPM and torque of 560 @ 2000 RPM and weighs in at 5411 lbs and its tow capicity is 13,700 lbs.
Say what you want about the plastic, but in outright power, weight, and braking the newer trucks eat the older ones lunch.
