Tractor Talk Discussion Forum
1070 case transmission
Evert Vankammen
03-08-2006 19:47:05
My 1070 case has a transmission problem.
A few of the symtoms are: After the clutch is let up tractor backs up afew feet and then goes ahead while it is in a forward gear. {real scary when you are backed up to a ditch}.
When you push in clutch tractor also brakes.
Power shift sometime does not work. And some days everythingworks just fine. Anybody any idea what my problem is?
c hess
03-09-2006 18:46:01
 Re: 1070 case transmission in reply to Evert Vankammen, 03-08-2006 19:47:05
Book says c2 clutches might be warped orinching spool not adjuster correctly. I assume you are idling when you push clutch in an tractor is warm. Since these tractors are getting old i would remove floor plate an make sure cable is moving freely an little cast piece is not binding on its pivot than with tractor stopped move power shift back an forth an check if valve is moving in its different positions corectly. I believe each position will be held by a detent. This you can do before you need to spend money at dealer.
Leland
03-08-2006 21:25:05
Better call the tech and let him put his gauges on and see what you are going to spend money on to fix .
