Tractor Talk Discussion Forum
stuck engine problems
zach16
03-09-2006 09:17:54
What kind of damage could be done to an engine if you run it with no oil pressure long untill the engine stops and is then stuck?
IHnut
03-09-2006 16:40:34
 Re: stuck engine problems in reply to zach16, 03-09-2006 09:17:54
Got a boat?
You've got a good anchor!
old
03-09-2006 10:05:14
Well if you ran it that long the rings and sleeves will be bad, the cam bearing bad. Crank shaft and main/rod bearings bad. And maybe a few other things.
ejr-IA
03-09-2006 09:28:55
Not good probably trashed the crank ,rods and bearings.
