Tractor Talk Discussion Forum
ph welder
therigwelder
03-10-2006 19:11:55
i posted earlier in the week about this welder,its a 69 p&h, 300amp,f163 continental.
it had a bad vacum idler system..ive got it to weld great@ high rpms.does anybody know what the baseline rpms should be load and no load?also i need timing specs.
ive placed an electronic idler on it but havent been able to make it work.the magnetic plunger solenoid works good when i connect it to bat.voltage,however it wont work through the pc board when i strike an arc. i probably dont have it wired properly.I wired it like the hobart i scavanged the parts from
