Tractor Talk Discussion Forum
allis 440 good or bad and what is value of them
larry h
03-12-2006 06:27:51
i am looking at a ac 440 how good or bad were they and what do i need to look for
Eldon (WA)
03-13-2006 22:27:20
 Re: allis 440 good or bad and what is value of the in reply to larry h , 03-12-2006 06:27:51
It is a Steiger painted orange....AC didn't have time (or money??) to develop an articulated 4x4 so they bought them from Steiger in the beginning.
Brad Wright of MO
03-13-2006 13:30:24
Heres what I found!
Allis Chalmers
440
Manufactured: 1973 - 1977 Cost: (US Dollars) $38,179 Power: Engine (HP): 218 Drawbar (HP): 165 Engine: Manufacturer: Cummins Fuel: diesel - turbo Cylinders: 8 Displacement (ci): 555 ci Compression: Rated RPMs: Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Forward: 10 Reverse: 2 MFWD: standard Capacity: Fuel (Gal): 3-Point: Category: III,IV Lift (lbs): Power Take-off (PTO): Type: Rear speed (RPM): 1000 Tires: Ag front: 23.1-26 Ag rear: 23.1-26 Dimensions: Weight (pounds): 20,230 Wheelbase (inches): Length (inches): Width (inches): Height (inches): Ground clearance (inches): Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps:
the tractor vet
03-12-2006 07:49:21
I have worked on one for a guy back a few years a go . Sortof a simple tractor trippel nickel cummins 10 speed road ranger i think it is a 610 roadranger transmission belt driven hdy. pumps sorta a pain to change belts just make sure that the center pins are good and finding someone that can tune a trippel nickel correctly these day may be hard to find as valve set and setting the injectors makes all the differance in performace of a cummins and they do sound good working.
It's getting the best of
03-12-2006 08:38:05
 Re: allis 440 good or bad and what is value of the in reply to the tractor vet, 03-12-2006 07:49:21
What is a "trippel Nickel" engine?
ohio
03-12-2006 09:07:29
 Re: allis 440 good or bad and what is value of the in reply to It's getting the best of , 03-12-2006 08:38:05
v or vt555 (turbo) not cummins' best engine, but they do sound cool, like a v8 mack or a powerjoke w/ straight pipes! it's sort of a little vt903.
Bob
03-12-2006 08:50:44
555 (C.I.D.) V-8
