Tractor Talk Discussion Forum
Exhaust Manifold Problem
Tweeter
03-13-2006 10:11:09
The exhaust manifolds on a chevy 350 were cracked and now being replaced with different ones and now the bolt holes dont line up with the threaded holes in the head. What can I do you get them to line up?
Bob
03-13-2006 19:07:07
 Re: Exhaust Manifold Problem in reply to Tweeter, 03-13-2006 10:11:09
You are using shrunken up USED manifolds, right?
The are some pretty good reasonably priced new ones on the market now (sadly, chinese).
For the aggravation with trying to fit the old ones, you'd have been better off with a set of the new generic ones.
aslack99
03-13-2006 17:12:11
Yep you need a manifold spreader.Sounds fake but works great.Look for Snap-On truck.
Coloken
03-13-2006 13:57:14
Will just say that you are not the first. That is a standard problem . I had it 35 years ago.
Greg_Ky
03-13-2006 10:26:36
When you install your manifold in stall the two center bolts first then use the jack to spread the two outside ports until the bolt hole line up.
Greg_Ky
03-13-2006 10:21:11
You need a manifold jack I made several years ago now you can buy them from snap-on. copy and paste the address below. Cost is $26.90
http://buy1.snapon.com/catalog/item.asp?item_ID=10798&group_ID=1343
arlu49@yahoo.com
03-13-2006 10:20:04
you have the wrong manifolds take em back .
you might try header pipes they might or might not work for your unit .
UncleTom
03-13-2006 13:46:09
 Re: Exhaust Manifold Problem in reply to arlu49@yahoo.com, 03-13-2006 10:20:04
How far off are they? I know 305's have a little different bolt config.
