Tractor Talk Discussion Forum
Case DC 1952
roy stroud
03-13-2006 18:07:22
I presently have a ford 9n. Thinking about buying a case DC 1952. Anyone know anything about this tractor -- horsepower, durability, problem areas, etc.? Anyone with info, I would appreciate it. Thanks.
JDB
03-14-2006 11:57:58
 Re: Case DC 1952 in reply to roy stroud, 03-13-2006 18:07:22
Good old tractor. Most part still available through Case IH Dealers. Buy yourself a parts manual, the parts counter guy will thank you. Around 40 PTO horse. Live PTO and HYD. I have a 52 and a 53. The problem you will encounter is with 3 point implements. DC's used what is called an Eagle Hitch. It does not conform to modern 3 point hitch standards but you can use many 3 point implements by simply turning one of the lower pins in. The PTO shaft is really high on these tractors so keep your u-joints well greased and you won't have any trouble.
souNdguy
03-14-2006 05:48:27
How do you like hand clutches?
Soundguy
Glenn F.
03-14-2006 09:25:23
 Re: Case DC 1952 in reply to souNdguy, 03-14-2006 05:48:27
It's all what you're used to. Hand clutches clearly have their pros and cons. Glenn F.
Dutchman
03-13-2006 18:43:54
Go on the CASE site.....they will till you everthing you want to know.... MV
