Tractor Talk Discussion Forum
Light Bulb
Paul L
03-15-2006 22:18:44
Hey,
I have a front light on my CASE 430 that needs to be tapped in order for it to work. Is this the bulb or wiring? Thanks
Vern
03-16-2006 13:01:15
 Re: Light Bulb in reply to Paul L, 03-15-2006 22:18:44
On my JD 133 lawn tractor the "headlights" have quit several times but I have yet to replace a bulb. The vibration of the tractor wears off the center contact of the bulb. I just add a drop of solder there & put it back in.
That may be your problem. Pull the bulb & look aat the center contact.
Vern
john in la
03-16-2006 03:24:52
I would say it is the bulb.
If the bulb filament is broken hitting the bulb sometimes makes the filament touch and the bulb comes on.
Now if you have to twist the mount or shake the bulb brackets; that would be a bad ground.
Nebraska Cowman
03-16-2006 03:19:36
Probably a poor ground
