Tractor Talk Discussion Forum
gravely smoking
troy perdue
03-16-2006 14:21:05
my dad is trying to fix my gravely. he says that all the oil is going up in the motor and is coming out around the spake plug he took it a part and said he thinks the oil ring is bad but the walls are ok can he put new rings in and is there a ring you can buy from napa that will fit he says it is a 52 or 54 modle two wheel he checked all the lines they are open
Nebraska Cowman
03-16-2006 17:15:20
 Re: gravely smoking in reply to troy perdue, 03-16-2006 14:21:05
Troy, if you measure the cylinder bore (or it may be listed on the engine serial number plate) and the thicknes of the rings NAPA or any good parts house should be able to get them for you. The cylinder walls don't want to be mirror shiny, when honed they should have a nice criss-cross pattern. third party image
