Tractor Talk Discussion Forum
Case va tsx114 venturi
Kraig te Riele
03-17-2006 05:20:32
Hello, I need a venturi for a Marvel Schebler TSX114 carb off a Case VA, anyone know where I can get one or if another venturi from a different model would work? It is no longer available through Case. I was also wondering if there were any other brands using this model Carb? Thanks.
Glen in TX
03-17-2006 07:06:38
 Re: Case va tsx114 venturi in reply to Kraig te Riele, 03-17-2006 05:20:32
My Marvel Schebler / Zenith catalog shows a TSX 21/32" venturi is Marvel Schebler part # 46A-238 or Zenith number B38-100-16.7 and shows to be available in price sheet. Zenith isn't going to sell to you direct and have to go through a dealer. If that's the size you think you need I can get it for you too.
Bob
03-17-2006 06:16:00
Your Case would have a M/S #46-473 (21/32") venturi.
An 8N Ford uses a M/S #46-467 (11/16") venturi... 1/32" larger. Likely, it would work just fine.
If you have a CNH dealer nearby, you might check if the Ford part happens to still be available. (You'd need them to look up the Ford part number, rather than the M/S number I've posted.)
Other possibilities:
Link
http://cfiworld.com/
Glen in TX
03-17-2006 10:24:43
 Re: Case va tsx114 venturi in reply to Bob, 03-17-2006 06:16:00
Hi Bob, I'm just wondering if you have a Marvel Schebler or Case parts manual or why we come up with different numbers for the venturi? I just have the later Zenith/MS 1-800 and 1-400 catalogs. They don't show a exact listing for venturi on TSX114 but just show the smaller bore 7/8" TSX and list the 46A-238 as the 21/32" venturi which goes to new Zenith # B38-100-16.7 . Anyway just wondering so I can find right numbers for other Marvel Scheblers. Thanks.
