Tractor Talk Discussion Forum
OT: Need Mr. Goodwrench
Cosmo
03-19-2006 04:16:48
On my 88 Chevy 1500 the cruise control stopped working intermittently. For a while I could turn it off and on a couple of times and it would operate. Now it doesn't work at all. Any one have ideas as to what I can check before I give up and take it to the dealer. Thanks a bunch, Cosmo. P.S. For the forum police. I pull my tractor with it at times.
David Gray
03-19-2006 08:18:46
 Re: OT: Need Mr. Goodwrench in reply to Cosmo, 03-19-2006 04:16:48
Check your stop light switch. My 97 GMC did the same thing. I was going to replace the switch, but just wiggleing it and moving it solved the problem. Cruse works great now!
Cosmo
03-19-2006 10:33:15
 Re: OT: Need Mr. Goodwrench in reply to David Gray, 03-19-2006 08:18:46
Thanks, I'll try that too. Cosmo
bradk
03-19-2006 06:40:36
Yes,probably the turn signal lever.I've made quick work out of these by removing lower trim panel,lower column plastic conduit (square where the column wires run through),locating cruise wire connector under dash,and putting small(mechanic's wire) through the small hole at plug in spade.The lever pulls straight out,pull old lever and mechanic's wire through,attatch new wire & reverse procedure.Be gentle-sometimes takes a little coaxing,but can be done.~brad
Cosmo
03-19-2006 06:59:25
 Re: OT: Need Mr. Goodwrench in reply to bradk, 03-19-2006 06:40:36
Thanks bradk, I think I'll give that a try. Cosmo
MarkB_MI
03-19-2006 04:31:03
Probably the turn signal stalk. I had to replace mine twice. The wires to the stalk are small and break over time.
I would tell you which wires to ohm out, but I gave my stepsom my factory manuals when I gave him my pickup.
I hope
03-19-2006 05:01:08
 Re: OT: Need Mr. Goodwrench in reply to MarkB_MI, 03-19-2006 04:31:03
Thanks Mark, that would be my first suspect too, by the symptoms. Do you know how to get the control out or is that beyond a shade tree tinkerer such as me?
MarkB_MI
03-20-2006 03:31:48
 Re: OT: Need Mr. Goodwrench in reply to I hope, 03-19-2006 05:01:08
Brad gave you the right instructions. I couldn't remember how I did it, it's been so long, but his instructions sound right: Stalk pops right out with a good pull. The trick is routing the wires through the steering column, which is pretty difficult if you forget to tie a pull wire to the old pigtail.
Cosmo
03-19-2006 05:07:30
That name was supposed to be Cosmo. Don't know what happened:(
