Tractor Talk Discussion Forum
What's Your Opinion?
Allan In NE
03-19-2006 06:03:11
Mornin' Guys,
I need a tractor part and am toying with the idea of ordering from this site "just because".
Anybody had any experience with these parts and how long does it take to receive 'em?
Thanks,
Allan
greygoat
01-17-2008 07:54:36
 Re: log spltter in reply to andys, 01-16-2008 15:56:43
If you are working a hydraulic woodsplitter from
tractor hydraulics, then, speed is determined by
pump output in gallons per minute, (GPM), and the
machine may cycle faster as the tractor engine is
speeded up. Splitting force is determined by the
tractor output pressure, pounds per square inch,
(PSI), which is determined by the safety relief
valve setting of the tractor hydraulic system.
Force is also subject to the size of the splitter
cylinder. A 4 inch bore cylinder has 12.56 inch
of piston area. pressure times area equals tonnage
of force (12.56 X 2000 =25120) divide by 2000
lbs per ton equals 12 1/2 ton. the same 2000 psi
on a 5 inch cylinder, (19.625 inch area) is
39250 lbs which is 19.62 tons.
There are reducing valves which reduce pressure
going from a system to a component, but no valve
can increase pressure beyond that of system
pressure setting.
Determine system pressure, and knowing cylinder
size will allow you to calculate splitting force
robhkent
03-19-2006 06:51:46
 Re: What's Your Opinion? in reply to Allan In NE, 03-19-2006 06:03:11
Allan:
I bought a solenoid for my 560 from here. Reasonable price, shipping was fine and it arrived in a timely manner. The part is a quality part and is on the tractor right now. Now if I could just figure out how to get that starter to spin faster, everything would be great. Yes, brand new cables, very clean connections, and a 1000cca battery. Oh well I will get there sooner or later.
Rob
Test
03-19-2006 19:36:07
 Re: What's Your Opinion? in reply to robhkent, 03-19-2006 06:51:46
Test, please ignore. Thx
Allan In NE
03-19-2006 06:56:07
Thanks Buddy,
I got paid yesterday and I think I"ll hurry up and order some tractor parts before my wife has a chance to spend the funds on silly things like food and rent. :>)
Allan
Quebec Red
03-19-2006 15:37:38
 Re: What's Your Opinion? in reply to Allan In NE, 03-19-2006 06:56:07
Maybe I wouldn't put FOOD on the silly list.....Kinda like that stuff....is up there on the top of the list along with GOOD tail , IHs, and, of course the bunch here..... ..Rent? yeah if there are pennies left..... ... Alternate solution is Allan's open ended credit card!!!!! ! A h-ll of a good idea.....QR..
At least I think so and I hear no opposition....
Robhkent
03-19-2006 09:06:37
I have that same problem here!
I spoke with a friend yesterday who clued me in on how silly I was being about what that gooseneck was woth...
Rob
david from mo
03-19-2006 06:42:53
I've gotten parts here .A clutch ,front tierod ends, 3 point hitch parts. Received most in 3 days at that time it was A&I parts not sure but think they no longer are A&I.
