Tractor Talk Discussion Forum
carb problem
JEN
04-05-2006 17:00:27
MF 165 ZENITH CARBURETOR, PERKINS GAS MOTOR, 1967 ?? WAS RUNNING GOOD, LET SET FOR COUPLE WEEKS, NOW IT IS FLOODING AND WILL START, BUT WILL NOT STAY RUNNING. HAVE DONE ALL THE NORMAL CARB THINGS TO FIX THE FLOODING BUT NOTHING IS WORKING. HELP!!! THANKS!!!
JEN
04-06-2006 04:59:47
 Re: carb problem in reply to JEN, 04-05-2006 17:00:27
Thanks Glen & River Bottom Farmer. Will do as you suggested. Will let you know how we make out. Jen
Glen in TX
04-05-2006 21:35:08
Might want to first pull off the fuel line at carb and see if you got a good steady flow of fuel for a minute or more out the line? If not the sediment bowl, filter or tank is plugged up. May need to flush the tank out? Then if good fuel flow check out the carb. If you cleaned the carb out once and filled it with dirty fuel and crud from the tank you get to have fun again.
River Bottom Farmer
04-05-2006 17:47:59
What are you calling normal carb things? I would remove carb and inspect needle and seat and also check the float angle.Most usually the float lever should be level with the bowl win needle is seated in the seat or in the closed position.After that if every thing looks good put carb back together and screw adjustment screws in and turn back out 2 to 2 1/2 turns start the engine and let it warm up with the throttle at idle position turn idle screw in slowly until engine begins to run rough and turn out slowly only far enough to allow engine to smooth out.Then advance to full throttle and adjust the main jet adjustment screw in the same manner.This is the procedure I use and it always works for me. Hope this helps.....River Bottom Farmer
