Tractor Talk Discussion Forum
Belt Pulley in Quarts???
Matt from CT
04-06-2006 05:32:49
Hi Guys...
I haven't been around in a while...and even though I saw something from Allan that was green and air conditioned, I think I have the right place ;)
I have a '55 (Massey) Ferguson TO-35.
I noticed on the chart (linked) they list a spec for "Belt Pulley in Quarts"...and I have no clue what that is!
sammy the RED
04-06-2006 08:36:33
 Re: Belt Pulley in Quarts??? in reply to Matt from CT, 04-06-2006 05:32:49
The chart lists 0.35 quarts for the TO-20.
For your tractor, TO-35 it says, 1.0 quart oil for belt pully.
souNdguy
04-06-2006 06:24:14
Capacities
Belt pulley... ( measured in ) quarts .35 or about 1/3 quart gear oil in the belt pulley ( that bolts to the pto shaft to allow you to power a flat belt run device ).
Soundguy
Matt from CT
04-06-2006 18:34:47
 Ah, that answers it... in reply to souNdguy, 04-06-2006 06:24:14
The PTO Belt attachment!
Minn. Norske
04-06-2006 05:58:54
Read that chart again! That 35 is the amout of gear lube it holds
steveormary
04-06-2006 10:34:19
 Re: Belt Pulley in Quarts??? in reply to Minn. Norske, 04-06-2006 05:58:54
My I&T FE-2 manual gives .35 qt"s as the capacity of the belt pully. I would use the same oil as is used in the trans. and diff. So I would go with souNguy on this.
steveormary
