Tractor Talk Discussion Forum
Has any one ever tried
old
04-06-2006 08:18:30
Heating oil up and pouring in the cylinder of an engine that is stuck or has stuck valves or rings?? If I heat oil up to around boiling and pour it in will I hurt any thing?? I have one tractor right now that sems to have 0 compression on one cylinder and very low on another cylinder and I think its from either stuck valves and or rings. What do you guys think??
Thanks for any ideas
davpal
04-06-2006 22:54:41
 Re: Has any one ever tried in reply to old, 04-06-2006 08:18:30
Shoot the cylinders full of PB Blaster. I have never seen anything free up rusted stuff as well as that stuff does. If it don't work, its called wrenching, and getting to know your tractor engine! Good luck.
Dave NE IA
04-06-2006 16:52:53
Had a old F20 that did that alot, start it up and 1/2 throttle and use a pump oil can with kerosene in it. Pull air cleaner hose off and pump her till the engine almost dies. Then as soon as she catches her breath give her another one. So far it has always come out of it. Dave NE IA
`Bernie in MA
04-06-2006 15:25:21
I've freed up stuck valves in Wisconsin engines many times by putting the short end of an allen wrench thru the sparkplug hole and rotating it until it's over the valve, then tapping it down with a small hammer. Take the wrench out, turn the flywheel til it sticks up again and repeat. Make sure it isn't where the cam is holding it up. When it snaps back down with just a tap you're almost there. Use Kroil or your favorite juice while doing it.
mjbrown
04-06-2006 12:46:08
Here is a trick I saw used on an airplane with a stuck valve.
Take out the spark plug and push clothsline sized rope in the hole. Push in a bunch but leave a good tail outside to pull it back out . slowly turn the engine over to bring the piston up which pushes the rope up against the valves and pushes them shut. That cylinder should be on a compression stroke so the valves can close when pushed.
Mike M
04-06-2006 11:46:57
At this point I don't think you have anything to loose. Just don't get that hot oil on you !
Steven@AZ
04-06-2006 11:08:02
I have successfully freed stuck rings and valves by running some Marvel Mystery Oil in with the crankcase oil. I don't know how severely they were stuck, but oil consumption went down and compression went up.
Hot oil down the spark plug hole won't hurt anything as long as you don't put the plug back in until the oil is out. The regular heating and cooling of the engine might break the rings free as well. A stuck valve could be a tougher problem to fix.
ESKIMO
04-06-2006 11:02:53
I THINK THE OIL WOULD LOSE ITS VISCOSITY ;MIGHT AS WELL TRY KEROSENE
the tractor vet
04-06-2006 08:36:28
My self i think the only cure is some nut and bolt twisten .
RodInNS
04-06-2006 18:46:44
 Re: Has any one ever tried in reply to the tractor vet, 04-06-2006 08:36:28
I think you're right about the nut and bolt twistin. I don't want to sound like a critic, but sometimes I think we spend more time looking for a quick remedy, when the quickest and cheapest solution is to pull the bloody thing apart and do it right. Dunno. Guess you do what makes ya happy.
Rod
RAB
04-06-2006 11:55:07
I second TV - after a compressed air test, after checking valve clearances.
Regards, RAB
