Tractor Talk Discussion Forum
IH 284 Carb or Fuel Pump problem??
BBfarms
04-06-2006 18:01:50
Just bought a IH 284 gas tractor (Mazda engine) previous owner had to pour a small cap full of gas into the carb to start. The tractor is starving for fuel at start up, I cracked the pump line, the gas flows very good after several cranks. Either, carb cleaner or gas pored into the carb will start the tractor.
I cleaned the tank, screen in the sediment bowl and the filter screen in the end of the fuel line, and replaced the hose to the fuel pump. Is there anything else to check in the carb? Is this a bad fuel pump?
I questions this because it pumps good after it cranks for a little whileseems like the carb should hold enough gas to start and run for the time it take the pump to supply the fuel/
Please help if you can...Bill Burger
dieselade
04-07-2006 04:44:06
 Re: IH 284 Carb or Fuel Pump problem?? in reply to BBfarms, 04-06-2006 18:01:50
is the choke cable working correctly. make sure the choke closes completely or it will be hard to start. be aware, parts for that tractor may be hard to come by.
noncompos
04-06-2006 23:22:55
I'll hazard a guess from my shade-tree mechanic days:if only takes one priming, if this happens every day, sounds like carb leaking into engine overnite, dry in morning until fuel pump fills it (yes, carb should have plenty fuel to start from day before): if can get top off carb easy, pull it before starting, see if bowl dry...ALSO google for mazda forums, check tech/engine section to see if general Mazda problem with a special fix...and post the cure when (if) you find it, we're usually dying of professional curiousity..good luck
