Tractor Talk Discussion Forum
Case 1370 engine problem
Marv
04-06-2006 18:48:33
Listed below are the symptoms:
Small amount of antifreeze in the oil. Bubbles in the radiator.
This tractor has had a history of heating up. Last time it was a cracked sleeve. Could it possible be the O rings around the sleeve or possibly a head gasket or cracked head? Any help would be appreciated.
Grumpy
04-07-2006 05:58:26
 Re: Case 1370 engine problem in reply to Marv, 04-06-2006 18:48:33
Bubbles in the radiator on a 1370 is probably one or more cracked sleeve. The sleeve landing the lip sets on at top of the block has to be the same all around. It cannot very in depth. A machine shop can cut this so it will be even.You can get shims from Case to bring sleeve back up to correct height. The shims are in the "90" series book. .005 and .010 shims are available. Stan
jhill
04-06-2006 19:31:47
Could be any of those.
