Tractor Talk Discussion Forum
frustrated with tractor
sal bartolotti
04-10-2006 14:38:18
restored tractor fully when i start get black smoke had marvel carb on the tractor overhauled could not adjust fuel poured out of the air cleaner inlet. Put on zenith rebuilt what luck do I have same condition happening thick black smoke and fuel pouring out the air cleaner side of the carb.
Also got the mag to distributor conversion does this install and time just like the mag??
Mike (WA)
04-11-2006 08:25:05
 Re: frustrated with tractor in reply to sal bartolotti, 04-10-2006 14:38:18
In addition to checking the float level, also check to make sure the float doesn't have a tiny hole that is allowing it to fill with fuel and sink.
Jerry/MT
04-10-2006 16:01:43
CThere's nothing wrong with your tractor! Check the float setting on your carburetor. If fuel is running out the air horn, your float valve is open. Either the float level needs adjusting or something is holding the float valve from closing.
old
04-10-2006 15:52:58
More info would help to help you. What brand/model tractor do you have. Carbs and distutor/mags are differant depending on what brand of tractor you have
Jerry Cent. Mi.
04-10-2006 15:23:27
It appears that you have an updraft system and your carb. is way to rich and the unused gas is running back down the intake and out the carb. Most carbs. have an air adjustment screw and a mixture adjust screw that allows more gas into the intake. The mixture screw has the large knob. Try turning both screws in and backing them out about 1 and 1/8 turns. That could be a good place to start.
Joe(TX)
04-10-2006 15:19:45
My opinion is the carburator is still not right. If fuel runs out the air cleaner it"s the needle ot float. probably the same causing the black smoke if not the adjustment.
Can"t help on the timing.
