Tractor Talk Discussion Forum
rear wheel
Gapper
04-11-2006 09:07:19
last year my 8n developed a problem on the right, rear wheel (right wheel when sitting in seat)around the hub, it started leaking grease, fairly heavy. I realize there is a problem, and a seal might need replace can anyone out there elaborate on what needs done, degree of difficulty and what the name of the seal is and where it can be purchased? Thanks,
Mark H in Mo.
Nebraska Cowman
04-11-2006 10:20:49
 Re: rear wheel in reply to Gapper, 04-11-2006 09:07:19
better check with a Ford mechanic. The hubs get loose
old
04-11-2006 09:44:21
Not to bad of a job but if the tires are filled with fluid it is a little harder to do. I would also replace the bearings when I did the job that way you know you have good parts there. Since your in Missouri I know you have O'riellys store close to you and you should be able to get parts from them. But any good tractor dealer can get you parts also
Bob
04-11-2006 09:19:06
Is it leaking by the nut, or inboard by the brakes?
Also, need to know the serial #, as the rear axle sealing system was changed on the later units.
