Tractor Talk Discussion Forum
Ford 4000 utility diesel
tim(sd)
04-12-2006 18:04:53
I"m not real wise when talking tractors hope you can clear up some questions for me.I"m looking at a 1964 4000 utility 3 cyl diesel,good looking tractor painted within last three years,starts and drives nice,a few minor oil leaks,3 point goes up and down good.Pto stayes on all the time even when disengaged,the guy said when hooked up to equipment and when disengaged it dosn"t turn.Is this of great concern?I took a few numbers off the tractor the engine numbers that I noticed are 3L302 and ahead and below the seat was DONN 6015.I am looking at this a an acreage tractor and want to put a loader on it,would it be a decent loader tractor for light duty?the guy said it"s a 50 horse tractor is this right?It has 3700 hours on it tach works He is asking $5000 is this a fair price?Any thoughts or advise would be appreiciated,
Thank"s Jim
kevaub
04-12-2006 20:04:57
 1964 4000 ford in reply to tim(sd), 04-12-2006 18:04:53
i have 1964 4000 ford industrial diesel tractor for sale for 4000 dollars. i beleive 1964 was the last year for the rounded hood style tractors and its also the last year for the 4 cylinder diesel engines. after 64 the 4000 tractors had 3 cylinder diesel engines.
does this tractor your looking at have select o speed tranny in it? if so, be very careful. they are notorious for problems. especially the early models. souds like alot of money for that tractor. you can probably buy one with a bucket already on it for not much more than that. especially if your not in a hurry and you look aroud. just my opinion.
tim(sd)
04-12-2006 20:16:45
 Re: 1964 4000 ford in reply to kevaub, 04-12-2006 20:04:57
This 4000 does not have the rounded hood,it is squared off like the newer one's,I'm starting to think it may be newer than a 64.Thanks
Tim
JDknut
04-13-2006 03:40:29
 Re: 1964 4000 ford in reply to tim(sd), 04-12-2006 20:16:45
It is a 1965 or later, if it has the squared off hood and a 3-cylinder engine. The 65-68's had a separate rectangular grill with a white insert covering the top 1/3 or so of the whole front area, on the 68's and later the grill was just one big rectangle. Depending on the type of PTO, the PTO turning even when disengaged, might not be too serious, the frictional drag of the oil in the system can let the shaft turn when disengaged with no load. I have seen that with a TLB set up to dig and the back end raised with the wheels off the ground on the outriggers, the rear wheels will sometimes turn even when the machine is not in gear, this is just the churning of the oil. But if it is a dry clutch PTO you might want to check the clutch adjustment. just my $0.02.
