Tractor Talk Discussion Forum
stupid question
jim hynden
04-13-2006 07:19:31
I have a stupid question . Where do you measure a plow to see if it is a 14", 16", etc?
jim hynden
04-14-2006 21:02:49
 Re: stupid question in reply to jim hynden, 04-13-2006 07:19:31
Thanks to all for the excellent input. Jim
steve in in
04-13-2006 18:07:44
Here look at this:
sammy the RED
04-14-2006 05:11:31
 Re: stupid question in reply to steve in in, 04-13-2006 18:07:44
third party image
You mean this one ?
steve in in
04-14-2006 05:37:09
 Re: stupid question in reply to sammy the RED, 04-14-2006 05:11:31
That would be the one.
Ross Pugh(NC)
04-13-2006 15:10:09
Jim, that is not a stupid question. I am 60 yrs old and have wondered the same thing, nobody could answer me either. I have a single bottom plow. How do I find out if it is a 12, 14, 16? Can anybody tell me? I can't measure between the beams.
eroy
04-13-2006 15:48:59
 Re: stupid question in reply to Ross Pugh(NC), 04-13-2006 15:10:09
Measure at a 90* angle from the flat of the landside to the rearmost cutting part of a fairly new share (Not wore out one) and you will come close to those 12", 14", 16" measurements, probly just slightly under the listed size.
dab
04-13-2006 07:24:23
As you stand behind the plow there are main beams that run from front to back. Measure from center to center and that is how big the plow is.
jim hynden
04-13-2006 07:47:00
 Re: stupid question in reply to dab, 04-13-2006 07:24:23
Thank you for the prompt reply. So it has nothing to do with the actual size of the plow shares, but rather the spacing between the framework that they are hung from ?
JMS/MN
04-13-2006 08:54:26
 Re: stupid question in reply to jim hynden, 04-13-2006 07:47:00
Like dab says- plows are measured at the beams. Putting on a longer share means nothing- it's just recutting what the previous bottom already cut.
mjbrown
04-13-2006 08:15:14
It does have something to do with the size of the plow share. The share cuts a furrow at an angle. A longer share can cut a wider furrow at that same angle.
paul
04-14-2006 05:44:42
 Re: stupid question in reply to mjbrown, 04-13-2006 08:15:14
But my 4-18 plow will accept 16, 18, & 20 inch shares. Does not change the width of the plow cut at all. 20 inch will do better on alfalfa roots; 16 inch will leave a gap under some conditions.
So it still comes down tot he beam spacing, not the plow share length.
--->Paul
