Tractor Talk Discussion Forum
a good bearing/seal interchange
mlm
04-13-2006 18:51:00
the Timken seal/bearing inerchange will cross many seal, bearing and factory parts lists numbers. The seal numbering system is the same as National's.
Link
This is a test to see post it right to make it active.
Wish I could find BCA/National interchange
There is a C/R - SKF interchange,but it does not seem to baas good.
NC Wayne
04-14-2006 18:19:28
 Re: a good bearing/seal interchange in reply to mlm, 04-13-2006 18:51:00
Here's a link for you to check out. There are interchange guides for just about everything you might need when it comes to bearings, seals, etc. The new sets are extremely high priced but you can get the ones that are a few years old pretty reasonable.
Myron KY
04-14-2006 06:11:22
I have this site saved for a National cross reference. I've never used it, so I can't say how good it is.
I think they are part of Federal Mogul now.
The cross ref. and lookup are under the Specification section.
National Seal/Bearing Cross Ref.
Myron KY
jc
04-14-2006 07:58:13
 Re: a good bearing/seal interchange in reply to Myron KY, 04-14-2006 06:11:22
Where abouts in KY are you?
Myron KY
04-14-2006 08:13:18
 Re: a good bearing/seal interchange in reply to jc, 04-14-2006 07:58:13
I live just south of Carrollton. Carrollton is about half way between Louisville and Cincinnati along the Ohio River or Interstate71.
Myron KY
jc
04-14-2006 07:57:28
mlm
04-13-2006 18:53:44
Nope, was not posted right to make it active. How is that done?
Don-Wi
04-13-2006 19:21:57
 Re: a good bearing/seal interchange in reply to mlm, 04-13-2006 18:53:44
Gotta paste it in the optional link url down below
Donovan from Wisconsin
mlm
04-14-2006 07:30:49
 Re: a good bearing/seal interchange in reply to Don-Wi, 04-13-2006 19:21:57
Hi Don,
Your link works.can you explain to me in newbe level what you did and were you got the "Timken" part to highlight.
Don-Wi
04-14-2006 22:32:09
 Re: a good bearing/seal interchange in reply to mlm, 04-14-2006 07:30:49
Down below the box for posting your messages, there are 3 boxes, Optional Link Url, Link Title, and Optional Image Url.
To post a link to a website, copy/paste the address inot the Optional Image Url box, then call it whatever you want in the Link Title box.
To post a picture, it has to be on the web somewhere already. Right click on it, click "properties". Copy the Image Url given and paste that in the Optional Image Url box.
It's a really simple process.
