Tractor Talk Discussion Forum
Cotter Pins
courtland
04-14-2006 11:50:00
Are cotter pins sized to the hole diameter or the lenght through the nut or both?
I've noticed that some cotters fit thighly in the hole, but seem to be to long, so can they be cut in this case???
KEB
04-14-2006 12:19:41
 Re: Cotter Pins in reply to courtland , 04-14-2006 11:50:00
Both.
Yes.
You should use the largest diameter that will fit through the hole. No problem with cutting them if they"re too long, just make sure you have enough length left to fold the legs over.
Keith
Mark - IN.
04-15-2006 03:30:54
 Re: Cotter Pins in reply to KEB, 04-14-2006 12:19:41
Absolutely.
Mark
