Tractor Talk Discussion Forum
Anyone used 1/8
Scott(IN)
04-14-2006 16:46:41
I need to replace a brake line on a old Clark forklift. Thought it would be an easy fix, but can"t find any 1/8" brake line. I see some line on Ebay that would work, but can"t find a double flare tool that small. Any brake double flare kits I see don"t go below 3/16. Heard an oil pressure line off of a Ford tractor might work if the fittings are the same, but it is 49 inches long. I need a foot.
RodInNS
04-15-2006 09:16:50
 Re: Anyone used 1/8 in reply to Scott(IN), 04-14-2006 16:46:41
I wouldn't think it hard to find an adapter to go up to a larger size line. Then just use 3/16" or 1/4" line, no problem. The line size itself will not make any difference, performance wise. HTH.
Rod
MarkB_MI
04-15-2006 04:33:33
Did you check with your auto parts store to see if they sell an adapter to fit stock brake line to your 1/8" fittings? Even if you have to special order it, it will be a lot simpler than buying brake line off of eBay and locating a special flaring tool.
2x4
04-14-2006 19:52:14
got couple boxes of new & used Clark forklift parts, including brakes lines if you need them.
Bloulbus
04-14-2006 17:30:23
Isn't 1/8" that stuff that comes in premade sections at the auto parts store?
Or should I have said "used to be" at an auto parts store?
Pooh Bear
04-14-2006 23:48:05
 Re: Anyone used 1/8 in reply to Bloulbus, 04-14-2006 17:30:23
Found some 1/8 flaring tools on the Grainger site.
Expensive buggers.
Mite also try the McMaster Carr site.
Pooh Bear
