Tractor Talk Discussion Forum
Will it work or just make a mess
John No Mi
04-15-2006 13:58:03
I am putting new tires on my MM 335. The rims are rusted on the inside. I am thinking about useing bed liner to coat the rims and fill the pits that are left after sanding most of the rust off. Will this work or will I be heading for trouble? Please let me know your thoughts on this.
souNdguy
04-15-2006 21:48:04
 Re: Will it work or just make a mess in reply to John No Mi, 04-15-2006 13:58:03
I had a super rusty 2n rim.. I wire wheeled it down, primed with a rust stop primer.. then painted 2-3 coats of epoxy gloss paint. Have not have a problem in a couple years with tubes getting torn up.
Soundguy
Jerry Cent. Mi.
04-15-2006 18:04:03
The tire repair people have a wide aluim. tape that can be wound around the rim.
John No Mi
04-15-2006 15:47:18
Thanks for the prompt and good answers. I will use the rust stopper and then paint. Will use a liner too.
BobReeves
04-15-2006 15:28:07
Had a flat on the right rear of my Ford 3000 right after I bought it. After the tire was removed we discovered the reason for the flat wass rust from the rim tearing holes in the tube.
Bought a new tube, cleaned up the inside of the rim with a wire brush in an angle grinder and ground off some of the real rough spots with another angle grinder.
Sprayed the rim with some rust stop I bought at the local auto parts store and after it cured put a good coat of Rustolium over the rust stop. Rim still had pits but everything was smooth. Haven"t had any more problems..
russ1
04-15-2006 14:30:20
If your desire is to stop the rust, you might use POR-15. It will absolutely stop the rust in it's tracks.
Ron in AR
04-15-2006 14:15:18
I assume you mean the spray on type bed liner? My thoughts are that in time, the bed liner spray will adhere itself to the tube. If it were me, I would just sand and paint the rims and get a rubber rim liner. It'll save you a lot of time and it'll protect your tube from chafing itself on any rough places on the rim. Just what I would do, if it were me.
