Tractor Talk Discussion Forum
Ok what happened
old
04-15-2006 16:01:58
I have a MH 30 that I was getting started so I could pull it in to the shop to work on it. I know the engine knocked some but figured it would at least make it 100 feet to the shop. Well it went puff, blew some smoke and the oil dip stich went flying. It then shut down and the oil pan is now leaking oil. I think I know what it did but want to see what you guys think. What say you.
Thanks. I think it blew by the way.
Pappy
04-16-2006 21:56:17
 Re: Ok what happened in reply to old, 04-15-2006 16:01:58
Before you tear it all down, consider this:
You might have gasoline in the crankcase and vapor ignition blew the oil stick out and blew the oil pan gaskets. It could have removed the valve cover, if it had one.
Too much "liquid" in the crankcase will cause a knock. I had a similar experience with a 6 cylinder Ford. Removed the excess oil and the knocking stopped.
Friend of mine had a 390 Ford badly flooded. When it ignited, it blew off both valve covers.
Drain the crankcase and see what you have.
old
04-17-2006 08:04:56
 Re: Ok what happened in reply to Pappy, 04-16-2006 21:56:17
Dip stick said it had the right amount of oil in it. The npan also now has a very small hole in it and it will not fire up again. I have tried to start it again but it keeps fire strange and when it does that the dip stick jumps again and if back fires out both the exhaust and intake.
J Cob
04-15-2006 17:49:03
From what I recall the MH 30 took an F 162 Continetal,,how many ya want??Exact same engine I ran on my drill rig,still got 2 or 3 of them kicking around here some wheres
old
04-15-2006 18:00:32
 Re: Ok what happened in reply to J Cob, 04-15-2006 17:49:03
Yep F162, I have another one and figure on makeing one good one from the 2 of them
Everett Mi
04-15-2006 16:26:39
What engine does a MF30 have? Just wondering. Everett
old
04-15-2006 18:01:44
 Re: Ok what happened in reply to Everett Mi, 04-15-2006 16:26:39
4 cylinder flat head cont. F162
Keith-OR
04-15-2006 16:12:36
Rich, kinda sounds like you blowed a hole in a piston then had a crankcase explosion.....Shame on you!!:>) :>)
Keith & Shawn
old
04-15-2006 16:17:06
 Re: Ok what happened in reply to Keith-OR, 04-15-2006 16:12:36
Bout time you said something to me again LOL. I sent you an e-mail yesterday explaining what I was doing with this MH 30. Oh well I was going to make one good engine from 2 of them any how. Just hoped I could at least drive the tractor in to the shop instead of haveing to pull it.
Keith-OR
04-15-2006 16:30:12
 Re: Ok what happened in reply to old, 04-15-2006 16:17:06
Been busy Rich, moving dirt from one place to another, Also had to get that ol VAC 3pt modified and tractor down the road. Sold it to a friend.
And it is Special Olypmics Tract time again.
Keith & Shawn
