Tractor Talk Discussion Forum
ford 60hp 4610 gear shif
ballast
04-16-2006 12:16:49
I am looking at a 4610 tractor with gear shif on colum..and have notice that some 4610'S have the shif on the transmission..Is this an earlier model or later model? and when did ford put the gear shif on the colum...I would appreicate any info...
RodInNS
04-16-2006 15:32:24
 Re: ford 60hp 4610 gear shif in reply to ballast, 04-16-2006 12:16:49
The column shifted 10's had the 8x4 syncroshift transmission, which was a new introduction when the 10's were introduced in 1982. The tractors with the top cover mounted shifters had the old 8x2 crashbox, which dates back to 1965. The 8x2 was about indestructable. The 8x4 gave some better ratios to work with, particulairly in reverse. The only problem with the 8x4 is th eshift pattern. Some people love them, and some hate them. For my money, I'd probably stay with the 8x2.... or go to a 30 series with the 8x8 if I wanted a real shuttle transmission. If you like driving it, go for it. There's nothing wrong with the 8x4.
Rod
ballast
04-16-2006 17:20:58
 Re: ford 60hp 4610 gear shif in reply to RodInNS, 04-16-2006 15:32:24
Rod..Thanks for the information...The asking price is $8000.00..with 3000 hours and they say it is an 1982...The engine sounds good and the tractor seems to run good...I am 62years old...and always wanted a tractor...any advice would be welcome...I want to put a winch on my tractor to pull logs out of the river,that I live on..and do bush hogging...
JDknut
04-17-2006 03:34:29
 Re: ford 60hp 4610 gear shif in reply to ballast, 04-16-2006 17:20:58
That's a good price and a good tractor, you'll like it. You will be surprised what you will be able to pull with it with a 3-point hitch logging winch like a Farmi or Norse.
