Tractor Talk Discussion Forum
IH 1466 Hydraulic fluid change
tomfritz
04-17-2006 12:50:15
Bought a used IH 1466 gas tractor last year. The past winter, I started it up, but the steering wheel would not turn the wheels. I guessed it was water in the hydraulic fluid and it was froze up. Now I am changing the fluid. The users manual says it has 22.5 gallons of fluid, I pulled the drain plug but only got about 5 gallons out. How do I get the rest of it out, do I need to drain all of the cylinders (front end loader) individually? There is no 3 point hitch.
Allan In NE
04-17-2006 13:44:47
 Re: IH 1466 Hydraulic fluid change in reply to tomfritz, 04-17-2006 12:50:15
Tom,
Are you sure we're dealing with a 1466?
Never heard of that rascal in a gas version. That's a huge tractor (150 hp) to be running on gas.
Fact is, the biggest IH 66 series I've ever ran across was the 766 gas. Interesting, to say the least. :>)
Allan
tomfritz
04-17-2006 16:34:28
 Re: IH 1466 Hydraulic fluid change in reply to Allan In NE, 04-17-2006 13:44:47
Just a senior moment, it is diesel
JMS/MN
04-17-2006 13:08:15
No need to drain cylinders. If you got only 5 gal out of a 22 gal sump- that's likely why the steering didn't work- simply low on oil. Hydraulic system usually has a priority valve that sends the first few gpm to the steering system, rest for hydraulic remotes, 3ph, transmission if hydraulic controlled. Did you check oil level before starting to drain it?
tomfritz
04-17-2006 13:23:15
 Re: IH 1466 Hydraulic fluid change in reply to JMS/MN, 04-17-2006 13:08:15
Yes, the fluid level was at normal on the dip stick. Once things thawed out this spring, everything seems to work okay.
