Tractor Talk Discussion Forum
truck starting cold, or so I thought
Tim Shultz
04-18-2006 08:57:41
my 73' ford F-250 hax been starting cold.. it will start but you can't move till it warms up a bit.. I thought it was just a cold starter.. but you can go out 6-10 hours after you shut it down.. even on a cold day and it will fire right up and be good to go right off the bat.. so whats up? I would think it would be a cold starter all the time. and it does the same thing even when it's warm out.. just sputter for about a minute.. then seems nice and warm and runs great. PLEASE HELP! lol
Tim Shultz
RustyFarmall
04-18-2006 10:02:00
 Re: truck starting cold, or so I thought in reply to Tim Shultz, 04-18-2006 08:57:41
The first thing you should do is make sure the carb is still bolted down tight to the manifold. The 6 cylinder engines were really bad about this, but the V-8s would loosen up also. Next, make sure the auto choke is free moving and adjusted properly. After that, well, it's just the nature of the beast.
Mike M
04-18-2006 09:46:51
Awe the joys of the "good ole days" before fuel injection.
Davis In SC
04-18-2006 09:35:54
Was that the one you put headers on ?
MH
04-18-2006 09:31:12
Tim, I think that is just the nature of these older Fords. Worked for a farmer that had a early 70s model several years ago, on a cold winter morning we would have to let that old girl warm up for a few minutes before we moved it as well. I have a 73 F350 now, it is not quite as bad, but still have to wait 20-30 seconds before I can think about moving it when it is cold out.
