Tractor Talk Discussion Forum
Farmall A
Arbuckle
04-18-2006 11:28:18
Anyone know how to take the front pulley off the crank on a farmall A. I have one that is stuck I think, I tried a puller and could not get it to budge.
Keith-OR
04-18-2006 19:00:29
 Re: Farmall A in reply to Arbuckle, 04-18-2006 11:28:18
Yes sir. You need a special tool(bracket) that goes behind the pulley and a heavy duty puller to pull on on the bracket or you will break the lower pulley.
Seems like I just posted a picture of puller that I made to remove the pulley from my son's SC, same engine.
Here is what I made to remove son's lower pulley. HTH
You can use hydraulic jack, base against the 2X2 tubing (there are some bottle jacks that will work laying on their side)
Keith & Shawn
third party image
third party image
third party image
VAJerry
04-18-2006 17:43:00
There is no set screw. Go to the farmall page and do a search on the front pulley subject. There are several postings showing the way to pull it off. DO NOT USE A THREE PRONGED WHEEL PULLER YOU WOLL BREAK THE CAST PULLY. Do the search.
Brent A.
04-18-2006 11:56:19
There should be a set screw with a jam nut on it you will need to remove. Then it should come off with a three jaw puller. It may take a little elbow grease,the last one I did was really on there.
Arbuckle
04-18-2006 13:49:21
 Re: Farmall A in reply to Brent A., 04-18-2006 11:56:19
I sure cannot find any set screw that is why I am baffeled on this.
