Tractor Talk Discussion Forum
Need help with kohler engine!
Mike in Ind.
04-19-2006 12:33:15
Hello. I have a kohler 7hp engine in a cub cadet that is giving me fits. Had it running last fall now I can"t get any spark to the plug. I cleaned and checked the gap on the points, the plug is clean and might as well be new. With the key on I have power to both sides of the coil and at the points. I"m out of ideas and I can"t find anything in my manual that I missed. Thanks.
Bob
04-19-2006 21:04:48
 Re: Need help with kohler engine! in reply to Mike in Ind., 04-19-2006 12:33:15
Connect a test light to the POINTS side of the coil. (With the ignition "ON".)
Points open... light on.
Points closed... light off.
Engine cranking... light blinking as points open and close.
How does your's compare with this?
jlmtractor
04-19-2006 18:27:26
hey thanks mike in ind for the help on the wieght of oil that goes in the motor.
Steve Crum
04-19-2006 18:14:56
I've seen the push rod that opens the points from the cam stick. Usually worn or gooked up with oil sludge which is likely the case if your motor is 40 years old. The points seem to open and close fine when you turn the motor by hand, but the rod sticks when the motor is spun at speed by a starter/generator. Usually an easy fix. take the points off and pull the rod out and clean it. if its worn, replace it.
JT
04-19-2006 17:11:05
have you replaced the spark plug wire? If it is not a wire cored wire, you cannot get fire to plug. Do you have power to both sides of coil all the time or does it come and go as the engine is turning over?. you should have 12 volts to the pos side of coil, then the voltage to the negative side of coil should go from 12 volts to o volts and back to 12 volts as you turn the engine over. Did you file points with a point file then take a clean peice of paper and clean the contacts?? If you did not use a point file, you may have corrosion causing your problems. If you did all this, it should run.
jlmtractor
04-19-2006 16:40:38
while we are on the subject of kohlers i have a 8hp k181 and i was wondering if anybody knew what oil it took because i need to know to get it running. if i didnt that could be another 135.00 to get it bored not counting gaskets and piston and rod.
Mike in Ind.
04-19-2006 16:54:26
 Re: Need help with kohler engine! in reply to jlmtractor, 04-19-2006 16:40:38
Back when they were made I think they used 30w in the summer and 10w in the winter. I generally use 10w30. Mike.
MeAnthony
04-19-2006 14:16:20
Is the plunger that operates the points moving? I had B&S once that sat over the winter and that part corroded; wouldn't retract after opening points. I'll skim through my small engine book later, that's just the first thing that comes to mind, given what you've already checked.
Mike in Ind.
04-19-2006 14:26:38
 Re: Need help with kohler engine! in reply to MeAnthony, 04-19-2006 14:16:20
I checked that when I checked the points gap. So I don't think thats what it is. Mike.
old
04-19-2006 14:37:58
 Re: Need help with kohler engine! in reply to Mike in Ind., 04-19-2006 14:26:38
With the key on, if you open the points by hand do you see a spark?? If you don't your cleaning of the points probably didn't work
Errin OH
04-19-2006 15:25:07
 Re: Need help with kohler engine! in reply to old, 04-19-2006 14:37:58
I agree. They sure can look good and be gaped right and still not work. Take the wire off the points and touch it to ground, make sure you have good ground, over and over. See if you get spark on known good plug. If not then put a test light on the + side and do it again. If light goes out you have wiring troubles. If it stays lit, and you can verify the wire from the coil to the points is not shorted to ground, coils bad.
My moneys is on a set of points that look like they working but are not. BTDT many, many, times. Usally the first thing I do is rotate engine to open the points, then short the points with screw driver to see if everthing else is working.
