Tractor Talk Discussion Forum
White 2-180 Hydrual Shift
4440 puller
04-19-2006 16:09:56
I have a White 2-180, over under transmision. Overunder oil temp would get hot, no preasure, except when cold, it would react to Engine RPM"s.
I have the tractor all tore apart, engine and trans out of the tub. the only thing i have found so far is the bypass plunger seems to have not been seating correctly. We have tried to get the seat out for the bypass plunger but havnt been sucessful. The pump looks to be good, have tried changing fluid and filter before tearing down. Any ideas would be helpful as we are hoping to have this girl out running in the field this spring.
J Schwiebert
04-19-2006 18:36:13
 Re: White 2-180 Hydrual Shift in reply to 4440 puller, 04-19-2006 16:09:56
Would the oil get hot in all three ranges? Did you check the pressure in all three ranges. How much of the over under do you have apart?
AB
04-19-2006 16:57:25
Scroll down to the Oliver board and post this. Many knowledgeable White users read that board. Good luck!
klf
04-19-2006 16:35:02
Give Maibach Tractor a call at 1-800-808-9934. They seem to know a lot about the Oliver and White tractors.
