Tractor Talk Discussion Forum
9N Hydraulics
BLittle
04-20-2006 00:40:46
Bought my uncles old 9N before he passed away. She runs good but the 3 point won't lift. Is there anything with the controls that would cause this? Hoping it's something simple before I tear into the pump housing.
Thanks, Bill
B. Jones
04-20-2006 04:01:06
 Re: 9N Hydraulics in reply to BLittle, 04-20-2006 00:40:46
Bill, Is your PTO turned on? It is the little lever behind your left foot. For the 3 point to work the pto must be engaged. By the way to engage the pto you push the lever back with the clutch pushed down. They are a good old tractor.
BLittle
04-20-2006 07:12:39
 Re: 9N Hydraulics in reply to B. Jones, 04-20-2006 04:01:06
When you say engaged do you mean engage the pump to the PTO shaft? Because the PTO shaft is turning now. I thought as long as the shaft was turning the pump was engaged.
BLittle
04-20-2006 08:14:14
 Re: 9N Hydraulics in reply to BLittle, 04-20-2006 07:12:39
Well I answered that last question myself. I couldn't shift the PTO so I removed the side cover and the lever was out of position and not engageing the PTO. I realigned and it shifts properly but still no Hydraulics. You can see a vary small amount of movement, maybe 1/8" at the large center spring. But if you blink you'll miss it.
Bill(Wis)
04-20-2006 03:05:07
There are world class experts on 9N hydraulics on the 9N,2N,8N board of this website and they rarely come over to this board.
