Tractor Talk Discussion Forum
2 stage hydraulics
Paul In On
04-20-2006 10:05:55
How can you tell if the hydraulics for a loader are two stage? Hope everyones day is going good. Paul
Paul in On
04-20-2006 13:55:40
 Re: 2 stage hydraulics in reply to Paul In On, 04-20-2006 10:05:55
Sorry about that everyone. I was reading somewhere that in order to have down pressure on a loader you need a 2 stage hydraulic. I'm pretty sure that's what it said. Paul
Old Pokey
04-20-2006 12:18:06
If you are running the loader from the tractors hydraulics, it is not likely 2 stage. If you have a pto pump to power the loader, it is still not likely, bt it is possible that you have a 2 stage pump. The 2 stage pump is commonly refered to as a "log slitter" pump. Here is a link to a place that sells 2 stage pumps. It has a picture and a brief description of a 2 stage pump.
old
04-20-2006 11:45:34
If your talking double acting then it will have 2 hoses. If you talking about a true 2 stage cylinder then it would have one stage that comes out then when it has reached its limit of travel and 2nd stage comes out. Most large dump trucks use a muti stage cylinder, some up to 4 stages
JAS,Tn.
04-20-2006 11:13:21
Do you mean double acting versus single acting cylinders
Paul in On
04-20-2006 13:57:32
 Re: 2 stage hydraulics in reply to JAS,Tn., 04-20-2006 11:13:21
That's exactly what I'm talking about. Do you not need a double acting to get donw pressure? Paul
JAS,Tn.
04-21-2006 09:28:34
 Re: 2 stage hydraulics in reply to Paul in On, 04-20-2006 13:57:32
Yes, you need double acting cyl. for down pressure.My loader is single acting on the arms that lift,but double on the bucket.You can get some down pressure by tilting bucket if it has double acting cyl.
Hope this helps you
John
petetx
04-20-2006 15:37:34
2 stage = 2 hoses you can put down pressure as well as up
my 3 pt. on my c-farmall is fixed this way nice on the post hole auger in hard ground.
Allan In NE
04-20-2006 10:24:38
Hi Paul,
Do the cylinders have two pistons? Don't really follow ya, I guess.
Allan
third party image
third party image
Paul in On
04-20-2006 13:58:25
 Got pictures of everything in reply to Allan In NE, 04-20-2006 10:24:38
Allan,
You got pictures for everyone's problem practically, don't ya?
