Tractor Talk Discussion Forum
Ain't purdy, but it works
RustyFarmall
04-20-2006 12:48:08
Couldn't keep the belt tight on the air compressor. Discovered the motor frame was actually tearing apart where it is welded to the mounting plate. Didn't want to buy a new motor, so I did a farmer fix. Initial testing is successful. Only time will tell.
third party image
Xragman
04-21-2006 06:31:27
 Re: Ain't purdy, but it works in reply to RustyFarmall, 04-20-2006 12:48:08
Looks very simular to mine. I used 2springs because I figered it was the starting torque that was tearing it up.Ben working good for 15 years,so maybe not a temp. fix.
NC Wayne
04-20-2006 23:20:00
WHERE'S THE DUCT TAPE????? ????? ????? It ain't really fixed til you use at least half a roll..... .
led
04-20-2006 20:17:29
Thanks Rusty; That photo helps justify 90% of the stuff that I do.
Led
UncleTom
04-20-2006 15:52:01
I seen a guy weld one like that and then cool it quick with a wet rag.
RustyFarmall
04-20-2006 17:18:02
 Re: Ain't purdy, but it works in reply to UncleTom, 04-20-2006 15:52:01
I toyed with that idea, but decided I wasn't that brave.
730virgil
04-20-2006 13:53:19
around here it's what is called getting virgiled
David Bate
04-20-2006 13:25:59
Bought a 1962 Allis Chalmers 272 (British built updated Allis B) last year. The bolt holding the strap which tightened the generator belt had sheared off in the block. The farmer had tightened the fan belt by jamming a small rock between the generator & the manifold. He said it had worked perfectly since about 1982 !!!
Shows farmers are the world's greatest inovators & engineers.
Harley
04-20-2006 12:52:23
Hey Rusty, I got a whole shop full of that stuff. It's only temporary, well unless it works. Harley
RustyFarmall
04-20-2006 13:04:14
 Re: Ain't purdy, but it works in reply to Harley, 04-20-2006 12:52:23
I hear ya, this compressor is 10 years old and has had extensive use. I kinda think this repair will do it until I can afford a new unit. If the strap had been there from the start it would never have broke.
Broomstacker
04-20-2006 17:20:58
 Re: Ain't purdy, but it works in reply to RustyFarmall, 04-20-2006 13:04:14
Don't wait too long, Rusty. The warranty on that board is only 15 years.....
RustyFarmall
04-20-2006 17:57:52
 Re: Ain't purdy, but it works in reply to Broomstacker, 04-20-2006 17:20:58
The board is part of a shipping crate for a hay rake that came from France. Being it is imported lumber it'll probably last forever. The steel band, on the other hand, is left over from when my Morton building was put up. I think the warranty is long gone on that one.
