Tractor Talk Discussion Forum
horsepower???
Ags
04-20-2006 19:28:17
how big of a plow (tandem, chisel, or field cult.) can a 170 hp drawbar tractor pull????
thanks
davpal
04-20-2006 23:00:40
 Re: horsepower??? in reply to Ags, 04-20-2006 19:28:17
You can probably go up to 30 foot disk and field cultivator if you want to work the tractor hard. I used to pull a 30 foot white 272 disk (extremely heavy disk) with a 2-155 white. It was ballasted with two saddle tanks and a rear three point sprayer tank for incorporating spray. That tractor ran very good and had ample power to get the job done. It never ran out of lugging power on that disk. We also used a 4-180 white on that disk which seemed to have about the same overall pulling horsepower as the 2-155 but would pull the equipment through much nastier conditions. If you had a wet spot it was not an issue as much as the 2wd 2-155 which would get stuck lots easier if it was a wet field. We also pulled 30 foot john deere field cultivator with the 4-180 all day with no problems, up hills and through wet spots on occasion. 4-210 was aquired later and seemed about the same pulling power as the 4-180 but was more refined for creature comforts. Old 4-180 was dirty and clunky and old but seemed as reliable as can be most of the time. I would also use a glenco 11 tooth soil saver in the fall with no problems. If these old brutes can do it you should be able to handle 30 foot equipment and 11 tooth chistle plows. But if you already have 24 foot stuff I would not replace what you have unless it needs to be changed. Good luck.
buickanddeere
04-20-2006 21:02:01
How fast do you want to travel? 30ft wide is possible with enough ballast and dearing down the transmission.
the tractor vet
04-20-2006 19:40:52
Well now alot depends on if it is MFA or just a two wheel drive in farrow or onland plowen in farrow around here 6 bottoms either 16 or 18 inch bottoms onland then 7 bottoms as for a disk if it has ft. assist then 24 footer with out on the hills 18 would be all ya wanted field culivator a 24 foot around here and may be 26 -28 in flat land chisel plow 10-12 and be able to maintain the 6+ mph .
Leland
04-20-2006 19:31:46
24ft culivator or disk and 12' chisel depending on soil types .
Ags
04-20-2006 19:44:23
 Re: horsepower??? in reply to Leland, 04-20-2006 19:31:46
see, i pull about a 24' field cultivator right now with a 1086 IH. Have a 13 shank chisel, a 15' heavy primary tillage disk, and a 22' Krause finishing disk that the 1086 pulls with no prob. that is only 130 hp. Now with a MFWD, I was wondering about upgrading some plows.
thanks
