Tractor Talk Discussion Forum
Case 2470, it now has 175HP
Mike S 806/H
04-21-2006 20:00:50
Thanks to everybody that replied about the Case only having 135hp, It now has 175 , Grumpy said check the precleaner and sure enough there was a huge mouse nest in there, took the hood off and removed the precleaner to get the nest out. also Dynoed the CaseIH 7130 Magnum it pulled 191hp, Now I just have to fix the power shift and some outer axle bearings and seals
farmermatt
04-22-2006 03:28:28
 Re: Case 2470, it now has 175HP in reply to Mike S 806/H, 04-21-2006 20:00:50
Just have to fix the powershift?? In what, the Magnum?? Just curious as to what the problem with it is. Sounds expensive.
